Hummer H3T Hummer no se podía quedar atras...
#1
Posted 13 January 2004 - 06:49 PM
Además del SUT, otro conceptual de la Hummer es el H3T, una verdadera camioneta. Cómo ves la caja de esta Forzo? con esta si te animas?
#2
Posted 13 January 2004 - 06:50 PM
Sea lo que sea, Hummer se lució con este diseño... elegante pero sin perder el estilo de troca...
#4
Posted 13 January 2004 - 06:53 PM
Por altura se ve ligeramente más chaparro que la Bronco conceptual y más chaparra definitivamente que el Jeep Rescue.
#6
Posted 13 January 2004 - 06:55 PM
HUMMER H3T CONCEPT VEHICLE SPECIFICATIONS
General
Body/chassis structure:
body on frame; steel body panels
Suspension
Front:
torsion bar with SLA
Rear:
5-link with coil over shocks/springs
Wheels:
19" x 8.5"
Tires:
285/65R19
Tire brand:
Nike-inspired BFGoodrich
Brakes:
disc with 15"-diameter rotors, 6-piston calipers
Dimensions
Height (in / mm):
70.6 / 1795
Length (in / mm):
174.9 / 4443
Width (in / mm):
74.5 / 1893
Wheelbase (in / mm):
118.6 / 3012
Track (in / mm):
Front:
65 / 1650
RearP
65.5 / 1664
Weight (lb / kg):
4650 / 2109
Bed storage (cu ft / L): 40 / 1133
Bed dimensions: 5 ft wide x 5 ft long x 1.6 ft deep(1.5 m wide x 1.5 m long x 0.5 m deep)
Powertrain
Engine:
3.5L turbocharged Vortec I-5
Technologies:
variable valve timing, variable intake manifold, 2-step variable valve actuation
Turbo intercooler type:
air-to-water
Displacement (cu in / cc):
211 / 3460
Horsepower (hp / kw @ rpm):
350 /260 @ 6000
Torque (lb-ft / Nm @ rpm):
350 / 474 @ 3600
Transmission:
Hydra-Matic 4L65-E 4-speed auto with AWD
Exterior:
Two-door unit body pickup truck (single-piece body and box)
Bed has two side access doors with fold-down tool box/step below door
Large, fabric, power-operated sunroof
Aluminum rocker covers/rock slider skid plates
Aluminum "Exoskeleton" structure (windshield surround, door opening)
Aluminum roof trim around sunroof with integrated LED marker lamps
Aluminum grille and brush guard (milled billet)
Hood-mounted air box on driver side and passenger side
LED marker and taillamps
Interior:
Seating for two
Nike-inspired materials throughout
Nike backpacks integrated to seatbacks
Cast rubber floor
Portable MP3 player/radio with docking station
Portable GPS/navigation system with docking station
Hood-mounted video camera (records events and displays in center console)
Analog/LCD combination gauge cluster (LCD portion is a vehicle inclinometer)
Fold-flat passenger seat
General
Suspension
Front:
Rear:
Wheels:
19" x 8.5"
Tires:
285/65R19
Tire brand:
Brakes:
Dimensions
Height (in / mm):
70.6 / 1795
Length (in / mm):
174.9 / 4443
Width (in / mm):
74.5 / 1893
118.6 / 3012
Track (in / mm):
Front:
65 / 1650
RearP
65.5 / 1664
Weight (lb / kg):
4650 / 2109
Powertrain
Engine:
Technologies:
air-to-water
211 / 3460
350 /260 @ 6000
350 / 474 @ 3600
Transmission:
Exterior:
Interior:
Seating for two
Cast rubber floor
#8
Posted 13 January 2004 - 08:49 PM
Aboganster,
No pos de que esta fregona, esta fregona...pero de a como ???
Oye y esas llantitas inspiradas en Nike han de salir en una lana...las venderán al publico...?
#9
Posted 14 January 2004 - 01:19 AM
esta perrona la trocka pero a de costar como dies tonka blue......
#10
Posted 14 January 2004 - 10:40 AM
NO PUES ESTA MUY BUENA LA TROKA... SALIO HACE POCO EN LA AUTOMORIZ, SI MAL NO RECUERDO LOS INTERIORES TAMBIEN FUERON DISEÑADOS POR NIKE.... TRAE MUY BUENOS ACCESORIOS...
PERO ESA YO LA TRAERIA PAL DIARIO Y EL RESCUE PA LA CHIN... O NO?? SI COMO NO.... SUEÑOS GUAJIROS
