Foros www.ajeepear.com: Diferencias del Cj5 y el Cj7 - Foros www.ajeepear.com
Diferencias del Cj5 y el Cj7 Plasma tus conocimientos Rate Topic: -----
#1 User is offline   drsierra
  • Vehiculo 4x4: Jeep Wrangler TJ 2001
Posted 03 September 2004 - 09:08 PM
Algunas diferencias visibles de estos dos CJ s
  • Attached Image: post-44-1094267298.jpg
#2 User is offline   lobito
  • Aprendiendo ajeepear
  • Interests:levantamiento de tarro , perseguir una que otra lobita , aaaaa y meterle mano a todos los fierros , aunque luego no me auerdo como se arman jajajajajajaja
  • Vehiculo 4x4: cj7 85 escarabajito FX
  Posted 03 September 2004 - 11:46 PM
:jajaja:/> Está buena la idea. saludos
#3 User is offline   joarzero
  • Jeepero De Taller
  • Interests:0
  • Vehiculo 4x4: Chevy Z71 1996/Jeep CJ-7 1984
Posted 04 September 2004 - 12:25 AM
aqui viene muy bien explicado
chequen este link:
http://www.quadratec...003102321330896
#4 User is offline   XE2YBG
  • Campero como las cabras....
  • Vehiculo 4x4: Suzuki
Posted 24 June 2005 - 12:18 PM
CJ7 ('76 - '86)
CJ5 ('76 - '83)
#5 User is offline   drsierra
Posted 24 June 2005 - 08:54 PM
DETALLES TECNICOS
CJ-5 (1955-1983)
Early model CJ-5 and M38a1
Description
Built from 1955-1971 (american motors Co purchased Kaiser Jeep in 1971)
the M38A1 was the military equivalent and was produced from 1951-1971
Round fenders
m38 had 80" Wheelbase, cj-5 had 81" wheelbase
59" wide windshield frame with bottom mounted wipers
windshield 90° to hood
side mounted spare tire
5"x5.5" bolt pattern on wheels
ENgines
F-head 134 cu in I-4
PErkins 192 I-4 Diesel
Buick 225 V-6 ("Dauntless")
Transmission
T-90 3 Speed manual
T-86 3 speed manual (used with the Buick v6)
T-98 4 speed manual
Transfer Case - Dana 18 2-speed transfer case
rear Axle
Dana 44 (through 1975)
front axle
dana 25 (through 1965)
dana 27 (1966- 1971)
Serial Numbers
1955 - 10001-27006 (Model 57548)
10001-10010 (Model 57648 ST CH)
10001-10001 (Model 57048-02 fire)
1956 - 27007-45922 (Model 57548)
10011-10022 (Model 57648 ST CH)
10002-10007 (Model 57048-02 fire)
10001-10006 (Model 56548 c/ws)
1957 - 45923-68815 (Model 57548)
10023-10068 (Model 57648 ST CH)
10008-10012 (Model 57048-02 fire)
10007-10012 (Model 56548 c/ws)
1958 - 68816-82877 (Model 57548)
10069-10136 (Model 57648 ST CH)
10013-10016 (Model 57048-02 fire)
10013-10015(Model 56548 c/ws)
1959 - 82878-97918 (Model 57548)
10137-10173 (Model 57648 ST CH)
10016-10017 (Model 57048-02 fire)
10016-10020 (Model 56548 c/ws)
1960 - 97919-119539 (Model 57548)
10174-10325 (Model 57648 ST CH)
10018-10023 (Model 57048-02 fire)
1961 - 119540-134747 (Model 57548)
10326-10386 (Model 57648 ST CH)
10001-10152 (Model 57558 diesel)
For more detail and information check out The illustrated jeep buyers guide by Jim allen
Later model cj-5
Description
Built from late 1972-1983 (american motors Co purchased Kaiser Jeep in 1971)
until 1976 body remained the same as early model cj-5 (see above)
1976-1983
Round fenders
83.5" wheelbase
55" wide windshield frame with bottom mounted wipers
windshield more sloped that previous cj-5
rear mounted spare tire
71.5" from from door hinge to rear
ENgines
amc 232 cu in i-6 (standard from 1971-1979)
amc 258 cu in i-6
amc 304 cu in v-8
gm 151 cu in i-4 (1980-1983)
Transmissions
t-14 3 speed manual (i-6 1972-1975)
t-15 3 speed manual (used with 304 v-8)*
t-150 3 speed manual (i-6 1976-1979)*
t-18 4 speed manual (i-6 1972-1986)*
t-176 4 speed manual (i-6, v-8 1980-1983)
sr-4 4 speed manual (i-4 1980-1981)
t-4 4 speed manual (i-4 1982-1983)
t-5 5 speed manual (i-4, i-6 1982-1983)
*known for being very stong
Transfer Cases
Dana 20 2-speed transfer case (1972-1979)
dana 300 2-speed transfer case (1980-1983)
rear Axle
amc 20 (1976-1983)
front axle
dana 30 (1972-1983)
CJ-7 (1976-1986) --------------------------------------------------------------------------------
Description
Built from late 1976-1986
Round fenders
93.5" wheelbase
factory roll bar
U door openning
81" from from door hinge to rear
ENgines
amc 258 cu in i-6
amc 304 cu in v-8 (last year 1981)
amc 150 cu in i-4 (1984-1986)
Transmissions
t-18A 4 speed manual (i-6 1976-1986)*
Chrysler 904 automatic (i-4 1981-1986)
chrysler 999 automatic (i-6, v-8 1980-1986)
GM TH-400 (v-8 1976-1979)
Transfer Cases
Dana 20 2-speed transfer case (1976-1979)
dana 300 2-speed transfer case (1980-1986)
BW1339 2-speed full time 4wd transfer case (AKA quadratrac)
rear Axle
amc 20 (1976-1983)
Dana 44 (some in 1986)
front axle
dana 30 (1976-1986)
